mondeo mk5 other features asbuilt
Dragunov
Re: mondeo mk5 other features asbuilt
Post by Dragunov »
Which hexcode do we need to change to have cornering light?
Dragunov
Post by Dragunov »
Somebody?
Vispen74
Vehicle: Ford Mondeo 2.0 Tdci 2015
Post by Vispen74 »
Hi!
I installed a sheep china rearview camera today, Mondeo Mk5, 2015.
Original APIM 7D0-01-01:
086B 8582 3386
Changed to:
020B 8582 3386, the 2 shoul activate the camera, but it gave me "contact dealer" if I left the 6. Changing it to 0 made it work.
With this line the camera is working fine, but the graphical parking sensor dissappeared, so now there is just camera in reverse, and nothing while moving forward. Can this be fixed so they work side by side?
Vispen74
Post by Vispen74 »
Another request:
To have the Speedometer in digits, shown on the instrument cluster, how is it done on a Mondeo 2015?
I tried IPC 720-07-01 to 0001 0000 002F, were 1 was 0 original.
Nothing shows up?
AmigaSurfer
Vehicle: Mondeo MK5 1.6l Ecoboost
Post by AmigaSurfer »
Vispen74 wrote:Hi!
086B 8582 3386
Changed to:
Add the 2 to 08 and leave 6B unchanged:
0A6B 8582 3386
AmigaSurfer
Vispen74 wrote:Another request:
Nothing shows up?
The old IPC on Mondeo 2015 shows the digital speedometer inside the analogue speedometer only. It only appears, if you disable the lane assist by pressing the button at the end of the turn-signal lever.
Some people flashed the 2015 IPC with the firmware from a 2016 IPC successfully, to get the digital speedometer between rev meter and speedometer. It's the same bit.
Vispen74
Post by Vispen74 »
Nothing shows up?
Ok, thanks!
So then I will look for a way to flash the firmware,if possible.
Vispen74
Post by Vispen74 »
AmigaSurfer wrote:
Vispen74 wrote:Hi!
086B 8582 3386
Changed to:
0A6B 8582 3386
This one worked like a charm, thank you!
robj20
Vehicle: Mondeo 2.0 TDI 180ps 2016
Post by robj20 »
I have the fuel graph enabled but it makes out at something like 45mpg, so all my lines are maxed out when doing 60+mpg. Are there any options to increase the graph max?
Dragunov
Post by Dragunov »
Nothing shows up?
Ok, thanks!
I flash my modules with UCDS.
Updated my IPC, DSP and ACM with it.
Enabled Corner Light, digital speedometer (middle screen) with it
