mondeo mk5 other features asbuilt
Dragunov
Re: mondeo mk5 other features asbuilt
Post by Dragunov » Fri Nov 18, 2016 7:04 pm
720-01-01
0C66-F464-6A5D
0C67-F464-6A5E
As u see u need to higher the last number of the first part with one, don't look to the checksum, FORScan calculates this automatically!
But if the last number of the first part is e.g an A, then u need to change it to B
I activated this feature on a Vignale yesterday, together with some other stuff and everything works as intended!
oddy
Vehicle: mondeo mk5
Post by oddy » Fri Nov 18, 2016 7:26 pm
I 20-01-01
0420 7464 2045 original value
0421 7464 2046 there I increased by one and nothing happened
0422 7464 2047 after that I increased again by one and appear in the menu lights flights delay by 10/20/120 sec.
I have a Trend option not Titanium or Vignale, should be different in my case? You have activated this option on Trend?
Dragunov
Post by Dragunov » Fri Nov 18, 2016 9:03 pm
Titanium class with digital IPC
mayak
Vehicle: Ford S-Max 2.0tdci
Post by mayak » Sat Nov 19, 2016 10:26 am
in Trend you need to enable autolocking in IPC and in BCM - and sometimes it still doesn't work :(
Dragunov
Post by Dragunov » Sat Nov 19, 2016 6:57 pm
So in fact on a Titanium, the BCM has already the changes for the autolock?
But it seems once a door is opened, the relock doesn't work anymore?
Also possible to change the color of the LED if the engine is not running?
So I have the LED in the door (behind the handle) on blue, when the engine is running, it changes to red when I open the door, but with the engine off, it stays Blue, I want to let the LED change color when I open the door from Blue to Red, even with the engine off.
Possible to change a hex code for this?
Thanks!
oddy
Vehicle: mondeo mk5
Post by oddy » Sun Nov 20, 2016 5:34 pm
Please help me with info where to change in BCM to have it autolock function enable it
Dragunov
Post by Dragunov » Sun Nov 20, 2016 6:49 pm
With those I cannot help, cause I don't know the line changed...
oddy
Vehicle: mondeo mk5
Post by oddy » Sun Nov 20, 2016 8:22 pm
I suppose than is in 726-15-01 , please tell me which value you have it here.
qfmrc
Vehicle: Fusion,1.5T,2013
Post by qfmrc » Fri Mar 10, 2017 3:36 pm
Dragunov wrote:Can somebody explain to me the difference hex codes for the tire pressure:
Vincent:
Tire Pressure (TPMS) Gauge:
720-04-01 xXxx xxxx xxxx
0 (Disabled)
4 (Enabled)
So: x4xx xxxx xxxx
Tool_Max:
Tire pressure control
720-04-01
1103 0284 00C6 became
1D03 0284 00D2
Andyv:
Tire pressure was originally
720-04-01
1103 0284 8046 became
1503 0248 8046
Thanks!
:D Thanks!
frizby66
Vehicle: Mondeo, 2.0 TDI/210, 2016
Post by frizby66 » Mon Mar 13, 2017 10:09 am
Hi, trying to find the TMPS values however when I look in BCMii settings, they all start 726 (see below):-
;Block 1
7260101010101010033
72601020A000101003C
;Block 2
726020101270101005A
7260202000100000032
;Block 3
72603010132
;Block 4
72604011501001E096F
7260402090C0C130067
;Block 5
7260501064001080284
7260502010102000038
;Block 6
726060101E00280059C
7260602F00000020027
;Block 7
72607010000138805D5
72607020000000A8CCC
;Block 8
7260801010100000038
7260802000000000037
;Block 9
72609015746304558A1
72609025890
;Block 10
72610015750434547B4
72610024180
;Block 11
726110133363231313C
;Block 12
726120101B407F62012
7261202C203
;Block 13
7261301810C60290057
72613020042
;Block 14
7261401000100010246
7261402141414140A9D
;Block 15
726150102020202024D
7261502010101010149
;Block 16
7261601010101010149
726160202020202024F
;Block 17
726170101010101014A
726170201010101014B
;Block 18
726180101010101014B
7261802000000000047
;Block 19
7261901000000000047
726190201010101014D
;Block 20
726200100000000004E
7262002010101010154
;Block 21
7262101140201010269
7262102010101000053
;Block 22
7262201010001010053
7262202000001010053
;Block 23
72623010253
;Block 24
7262401000100000053
7262402000000000053
;Block 25
7262501000001000054
7262502000000000054
;Block 26
7262601010100000157
7262602000001010158
;Block 27
7262701000101000057
7262702000000010057
;Block 28
726280101010101015B
7262802000000000158
;Block 29
7262901000000000158
7262902000000010059
;Block 30
7263001030300000064
726300200000000005F
;Block 31
7263101030201120C83
72631020C01000F5FDB
;Block 32
72632010A000000006A
72632020000000064C5
;Block 33
7263301010100010064
7263302000000000062
;Block 34
726340106210001008A
7263402000001000165
;Block 35
7263501000000000063
7263502000000000064
;Block 36
72636010104000B0074
7263602000100000066
;Block 37
7263701000100000167
726370200010202026D
;Block 38
7263801010100000068
726380200020100006A
;Block 39
726390111940101010F
726390201000101006B
;Block 40
72640010004202000B2
7264002010101010073
;Block 41
7264101030100010276
7264102000001010072
;Block 42
7264201000000000070
7264202000000000071
;Block 43
7264301010005000077
7264302000000000072
;Block 44
7264401010100010176
7264402000001010277
;Block 45
72645010A001100018F
7264502010101000077
;Block 46
7264601000101010077
7264602010001010078
;Block 47
7264701010100000178
7264702010000010078
;Block 48
7264801010000010179
7264802010000000179
;Block 49
7264901000000000077
7264902000400040181
;Block 50
7265001108E
;Block 51
726510100000000007F
7265102000000000080
7265103000000000081
7265104000000000082
72651050000000083
;Block 52
7265201000000000080
7265202000000000081
7265203000000000082
7265204000000000083
72652050000000084
;Block 53
7265301000000000081
7265302000000000082
7265303000000000083
7265304000000000084
72653050000000085
;Block 54
7265401000000000082
7265402000000000083
7265403000000000084
7265404000000000085
72654050000000086
;Block 55
7265501000000000083
7265502000000000084
;Block 56
7265601000000010186
7265602010101010089
;Block 57
7265701000101000087
7265702000000000086
;Block 58
7265801000000000086
7265802000000000087
;Block 59
7265901000100000088
7265902000000000088
;Block 60
7266001010000010191
726600200000000008F
Module details are:-
BCMii - Body Control Module
Part number: FU5T-14B476-BAN
Strategy : FU5T-14C184-AAL
Thoughts?
Frizzy
