mondeo mk5 other features asbuilt
zjohnny
Vehicle: MONDEO MK5 TITANIUM 150CV DIESEL
Re: mondeo mk5 other features asbuilt
Post by zjohnny » Sun Mar 01, 2020 11:06 am
I saw that there are some problems with this procedure
zjohnny
Post by zjohnny » Mon Mar 02, 2020 7:31 pm
Torque Steer Compensation it can be activated? what do you need to activate it? what advantages could you have?
zjohnny
Post by zjohnny » Mon Mar 02, 2020 7:45 pm
oddy wrote:
Thu Oct 10, 2019 6:55 pm
I intend to activate torque steer compensation and active nibble control on mondeo mk5 , is enough to have it modified in PSCM or is required
to have it in other modules as well?
730-01-02 x*xx xxxx xxxx Torque Steer Compensation (TSC): 0=disabled, 1=enabled
730-01-01 xxxx xxx* xxxx Active Nibble Control (ANC): 0=disabled, 1=enabled
Have you news?
moncho12
Vehicle: mondeo mk5 hibrid
Post by moncho12 » Sun May 03, 2020 11:37 am
Hello, good afternoon, sir. I have a mondeo hybrid 2018
I have an original rear camera, installed you see the camera only with the yellow and red green lines,
but you don’t see the dynamic lines as they are activated in PSCM?
in BCM I have changed the following lines:
BCM: 726-34-01 xx21-xxxx-xxxx
726-39-02 xxxx-x1xx-xxxx
without result.
that I have to change in PSCM to activate them.
thank you
Qjanusz
Vehicle: Ford Mondeo MK5 Hybrid EU
Post by Qjanusz » Sun May 03, 2020 5:11 pm
I have Mondeo MK5 Hybrid EU version 2015. TPMS sensors in standard. I tried enable showing pressure value on left 4 inch display , but I failed.
In IPC i have 720-04-01 1103-0080-8141
I tried combinatioons with
x4xx xxxx xxxx
x5xx xxxx xxxx
xDxx xxxx xxxx
xx4x-xxxx-xxxx
xx8x-xxxx-xxxx
xxCx-xxxx-xxxx
Nothing shows up. I still don't have menu, where I can turn on show pressure values.
Can somebody help me and tell how to enable this feature in Mondeo Hybrid version?
SoFlowJoost
Vehicle: Ford Mondeo hybrid 2017
Post by SoFlowJoost » Sun May 17, 2020 4:31 pm
The as-built values with ford hybrid are different then with the default vehicles. I'm bumping into this problems many times. There is way more documentation about the default non-hybrid vehicles. i didnt managed either to show the pressure values.
Dragunov
Post by Dragunov » Sat Aug 01, 2020 6:14 pm
Have you news?
I wonder where he got this info and how it exactly works?
Dragunov
Post by Dragunov » Sat Aug 01, 2020 6:28 pm
