mondeo mk5 other features asbuilt
vincenten
Vehicle: Ford, 2.0TDCI 150HP, MY2015
Post by vincenten » Mon Sep 05, 2016 5:50 pm
Goodevening
I am trying to unlock some features on my mondeo mk5. This includes the tire pressure being shown on the dials and the digital speedometer in the center. Is there anyone who has already found the bit that has to be changed or knows any other features that are possible to be enabled? I've already managed to enable autolock.
I'm also looking for a way to change the map on my 2.0 TDCI 150 hp to the stock one from ford with 180 hp. If anyone can help me with this I would be very gratefull.
Contact me through this post or through private message.
kind regards
vincenten
FOX
Vehicle: ford c max 1.6 TDCI
Re: mondeo mk5 other features asbuilt
Post by FOX » Mon Sep 05, 2016 7:42 pm
Good evening,
to do this kind of changes it would be preferable for you to use WinOLS because there will be several maps retouching ...
The ideal would be to see a pro.
Good luck friend!
vincenten
Post by vincenten » Mon Sep 05, 2016 9:25 pm
Good evening
I thank you very kindly! I will be seeing someone who can activate the 180 hp map on my car. He does this using UCDS. I thought if it is possible to do it through UCDS it might also have been possible through forscan. I can keep on hoping :)
right now i've already found: Autolock,speedometer gauge, TPMS gauge and changing of the time the 12V plug keeps delivering current after turning off the contact.
kind regards and thanks for the help
vincent
tomboy_c
Vehicle: Mondeo 2.0TDCi 210 2015
Post by tomboy_c » Sat Sep 10, 2016 9:09 am
Hi Vincent, how did you do the changes above? Did you use Forscan Extended?
I've come from using VCDS on my Passat which was great, now I need to get to grips with this on my Mk5 Mondeo!
vincenten
Post by vincenten » Sat Sep 10, 2016 9:05 pm
Good evening tomboy
Yes all the functions above were acivated using forscan extended license and altering the asbuilt files.
kind regards
vincent
Dragunov
Post by Dragunov » Wed Sep 14, 2016 8:13 pm
Can somebody explain to me the difference hex codes for the tire pressure:
Vincent:
Tire Pressure (TPMS) Gauge:
720-04-01 xXxx xxxx xxxx
0 (Disabled)
4 (Enabled)
So: x4xx xxxx xxxx
Tool_Max:
Tire pressure control
720-04-01
1103 0284 00C6 became
1D03 0284 00D2
Andyv:
Tire pressure was originally
720-04-01
1103 0284 8046 became
1503 0248 8046
Thanks!
FORDriver
Vehicle: 2016 Mondeo BiTurbo TDCI
Post by FORDriver » Wed Sep 14, 2016 9:24 pm
If you look at the values at a bit level instead of a byte level it should be obvious.
0x0 -> 0000
0x1 -> 0001
0x4 -> 0100
0xD -> 1101
0x5 -> 0101
Dragunov
Post by Dragunov » Wed Sep 14, 2016 9:43 pm
I know, but how does all of the above hex numbers affect the appearance of the tyre pressure monitor.
Cause all of them work perfectly, but there has to be a difference somewhere in them (under the hood).
Cause if u change a hex number, then it has a different outcome!
Some say u just need to change one bit (change it from 0 to 1), but if u change two bits to 1 (from 0), it works aswell, but as I wrote above, there has to be a different if u activate an extra bit...
But still try to find out what's the difference in behaviour of it
Ben78
Vehicle: Mondeo 2.0 TDCi 180 hp 2015
Post by Ben78 » Sun Sep 18, 2016 2:38 pm
For TPMS you have to activate bits 4 and 5 (counting from left beginning at zero), one bit activates the presure-display itself and the secound one activates the option to switch it between psi/kPa and bar. If you change value of other bits, it will affect other funtions then TPMS.
Dragunov
Post by Dragunov » Sun Sep 18, 2016 6:45 pm
Thanks!
