2011 Edge IPC flash failed/soft bricked
RSH98
Vehicle: Ford Edge, 3.5L V6, 2011
Post by RSH98 »
My 2011 Edge always fails at 71% on brick 2 of the ECU programming. What is going wrong? I have tried all firmware versions and have checked both force firmware update and stop activity on the buses. I am using 2.4.3
ipc update fail.txt
(3.94 KiB) Downloaded 38 times
MoJo88
Vehicle: Mondeo Vignale 210ps 2017
Re: 2011 Edge IPC flash failed/soft bricked
Post by MoJo88 »
First thing to check on failed firmware flash is what adapter are you using. So what adapter do you have?
try one by one
1.
sbl
BT4T-14C026-BS
2.
sbl
BT4T-14C088-BN
MoJo88 wrote:
Thu Apr 22, 2021 6:52 pm
or the battery is empty :!: :o
rgcarnevale
Vehicle: F150, Gasoline 3.5L 2011
Post by rgcarnevale »
Did you ever get this resolved?? I just had the same exact thing happen to my wife's 2011 Ford Edge. Gets through the 25 blocks of first load but then fails on 2nd block of calibration. Hope if you got yours fixed you could let me know how.
