DTC U3000:41-48 General Checksum Error
Posted: Sun May 24, 2020 6:44 pm
by Storkpkp
After flashing my firmware on my APIM I am getting this DTC. I don't see any adverse affects, but I was wondering if anyone knew more about this or had seen it.
Re: DTC U3000:41-48 General Checksum Error
Posted: Sun May 24, 2020 6:49 pm
by fordsmax471
after the flashing
did you restore APIM As Built data :?:
Posted: Sun May 24, 2020 7:03 pm
by Storkpkp
I just did that. It was seeing it as SYNC 1, so I had to write some values to get it to recalculate checksum. Then it allowed it to see it right. I then reloaded from my saved values. Is that the part where I am messing up. Do you have to manually write them?
Posted: Mon May 25, 2020 2:53 pm
by Andyfocus
if you have changed the original as built due to having modded the car then you dont load as built , you have load up the modded as built that you should have saved when you made the mods .
Posted: Mon May 25, 2020 7:09 pm
by Storkpkp
Um, wut?
Posted: Tue Feb 02, 2021 8:17 pm
by zjohnny
I have same problem, how can I solve? I have upgraded from sync2 to sync3
Posted: Sat Feb 06, 2021 4:59 am
by zjohnny
I have rewritten without modifies as-built, force restarted my module but error renaming! I have old style IPC version can it be that?
Posted: Wed Feb 17, 2021 11:50 am
by elpamyelhsa
Its a fimrware checksum error, this means you have a corrupt module firmware. Make sure you have a battery charger plugged in and "force" program the module to the same version as it currently is. Then the DTC should clear.
