Help! !! !! v2.4.0.test202000121 refreshes BCM crashes
Re: Help! !! !! v2.4.0.test202000121 refreshes BCM crashes
Post by fordsmax471 » Sun Mar 15, 2020 9:52 am
"I still have a 2019 F150 that can read the configuration file. Can it be used?!"
NO
you can to check obd adapter the 2019 F150
maybe able to get it back original profile if you make a restore point to your computer
ELS27v4/UCDSv4/Elitebook840G6/Win10pro
lxlxj
Vehicle: F150 3.5 2017
Post by lxlxj » Sun Mar 15, 2020 8:06 pm
The OBD voltage is 12V, and the key is 12V on or off.
OBD connected and disconnected operation results are the same
lxlxj
Post by lxlxj » Sun Mar 15, 2020 8:21 pm
all fuses normal
update 14F389
Keithmac
Post by Keithmac » Sun Mar 15, 2020 11:21 pm
Did you have a decent battery charger connected when you tried to flash the BCM?. My Kuga required a 12amp charger.
Also I'm sure I've read on here ELM adapters are no recommended for Module Updates?.
lxlxj
Post by lxlxj » Mon Mar 16, 2020 12:45 am
The external charger has been connected, the guaranteed voltage is 12.5V, I just want to test,I'm using ELS27, not ELM
lxlxj
Post by lxlxj » Thu Mar 26, 2020 8:56 am
Now I have used UCDS repair
Priscila.Guerini
Vehicle: ford,kuga,2.0,2013
Post by Priscila.Guerini » Sat Apr 11, 2020 8:19 am
Did you repaired the BCM module work with UCDS?
lxlxj
Post by lxlxj » Tue Apr 14, 2020 5:36 am
Has been repaired, and all modules have been upgraded to the latest version
Priscila.Guerini
Post by Priscila.Guerini » Wed Apr 15, 2020 5:05 am
:lol: seem like it's perfect with all are newest firmware, what different can you feeling with old version?
odirleitds
Vehicle: New Fiesta Sedan SE 2014
Post by odirleitds » Wed Jul 15, 2020 12:20 pm
Did you happen to use the ELS27 with the UCDS for this repair or did you buy the UCDS Pro with the UCDS interface?
