led headlight bulbs
Ngyafav
Vehicle: 2017 f150 stx supercrew
led headlight bulbs
Post by Ngyafav » Wed Jul 03, 2019 12:27 pm
Does anyone know which way aftermarket led headlights should be pointed in 2016/2017 f150 headlight housing? should the led's be pointing side to side or up and down in the housing? Ive installed new ones and after putting it all back together noticed my light is off and i looked at the bulbs and both my bulbs led resistors are pointing different directions in the housing. i need to adjust them just not sure which way they should point.
thank you
martynm
Vehicle: Everest 2.2 Diesel 2018
Re: led headlight bulbs
Post by martynm » Sat Jul 06, 2019 10:53 am
If it is the same set up as my 2018 Everest (Ranger SUV) then they must face horizontally to give the correct light spread.
