I have currently expanded it and made a test setup to test it
(Adapter: OBDLink EX
FORScan v2.4.5 beta3
IPC - instrument cluster
Part number: F1ET-10849-BLN
Code: Select all
Interface:
Typ: FTDI #1:223010206571, 2000000 bps
Adapter: OBDLink EX r1.0 STN2230 v5.6.5 (ELM327 v1.4b)
Min. Verzögerung: 2 ms ( Hervorragend)
Errors:
- CAN ERROR: 697 ( 14.8% )
- BUS ERROR: 3 ( 0.1% )
Fahrzeug:
Modell: Ford Focus
Motor: Duratorq Turbo Diesel Common Rail Injection Stage VI
Kapazität: 1.5L
Generation: 2015.25MY
Treibstoff: Diesel
Getriebe Zahnrad: Manual (Manuell)
PCM - Motorregelungs-Modul
Teilenummer: H1F1-12A650-DC
Calibration level: H1F1-12A650-DF
Strategie: H1F1-14C204-DF
Hardware type: F1F1-12B684-AD / F1F1-12B684-AC / F1F1-12B684-ZA
VIN: WFxxxxxxxxxxx
OBDII - On Board Diagnose II
IPC - Kombiinstrument
Teilenummer: F1ET-10849-BLN
Calibration level: F1ET-10849-BLN (latest known: F1ET-10849-BLX)
Strategie: F1ET-14C026-BBD
VIN: WFxxxxxxxxxxxx
Kilometerzähler: 999999 km
Abstand insgesamt: 0.0 km
(WARN) [09:13:51.893] Prüfe FTDI #1:223010206571...
(OK) [09:13:52.664] Verbindung zum Adapter hergestellt: FTDI #1:223010206571
(OK) [09:13:52.665] Adapter: OBDLink EX r1.0 STN2230 v5.6.5 (ELM327 v1.4b)
(OK) [09:13:57.782] Verbindung zum Fahrzeug hergestellt
(OK) [09:13:57.789] Fahrzeug: Ford Focus Duratorq Turbo Diesel Common Rail Injection Stage VI 1.5L 2015.25MY
(OK) [09:14:32.618] Modul gefunden: IPC - Kombiinstrument
(WARN) [09:14:33.462] DTCs im IPC: U2101:00-68, U0073:88-2C, U0140:00-68, U0121:00-68, U0151:00-68, U0233:00-68
(OK) [09:14:55.148] IPC Module firmware update wurde gestartet
(WARN) [09:14:55.159] Lese Fahrzeuginfo...
(WARN) [09:14:58.495] Unable to read current firmware p/n, use stored in profile: F1ET-14C026-BCB
(WARN) [09:15:04.889] Total size: 7.42 Mb. Estimated duration: 36m - 1h 12m
(WARN) [09:15:06.730] Loading SBL to primary module...
(WARN) [09:15:07.753] Loading block 1/1...
(OK) [09:15:15.450] SBL loaded successfully
(WARN) [09:15:15.506] Loading firmware to ECU: Strategy F1ET-14C026-BBJ
(WARN) [09:15:15.517] Erasing block 1/2...
(WARN) [09:15:18.583] Erasing block 2/2...
(WARN) [09:15:18.802] Loading block 1/1...
(OK) [09:21:50.921] Firmware loaded successfully
(WARN) [09:21:50.972] Loading firmware to ECU: Strategy F1ET-14C026-BCD
(WARN) [09:21:50.985] Erasing block 1/1...
(ERR) [09:21:51.007] Erasing blocks failed
(ERR) [09:21:51.616] Service Prozedur fehlerhaft, bitte Entwickler kontaktieren
