2020 Mk4 Focus
Cortinaman
Vehicle: Mk4 Focus 1.0 2019
2020 Mk4 Focus
Post by Cortinaman »
Just bought a Oct 2020 Focus Active X Vignale manual and wondered what changes I can make to the Sync system. I've managed to add the heated steering wheel icon but can't find an option for seats. Also couldn't find one for different coloured buttons for audio, navigation etc... Finally, I fancied changing the splash screen from showing the Ford logo to Vignale or something
lenko
Re: 2020 Mk4 Focus
Post by lenko »
APIM 7D0-02-01 xxxx x8xx xxxx - Vignale.
Cortinaman
Re: 2020 Mk4 Focus
Thanks for that, got that working now :D
Cortinaman
Re: 2020 Mk4 Focus
Just found the heated seat icon setting so have that now. Checked through the menu but don't have an option to change the icon button colours as I've seen some do... I also can't seem to get the speed limit icons to show on the sat nav window as |I've seen done in a video
Any other mods worth doing ?
davetcollection
Vehicle: Focus '17 ST-Line 1.0 Auto, Focus 4 1.5D Titanium
Re: 2020 Mk4 Focus
Post by davetcollection »
Cortinaman wrote:
Mon Jul 19, 2021 10:24 am
Classic theme, I believe.
Been an active X Vignale, your APIM start up screen should be Vignale anyway.
Don't use asbuilt codes go in and make changes using the drop down methods
Cortinaman
Re: 2020 Mk4 Focus
It does now but, when I bought it, it just showing the blue oval Ford logo. I did change it by changing it to an 8 as suggested above which it now shows Vignale but I did also notice it showed that in the APIM as built menu.
While in the APIM as built menu I did try to select the mirrors to dip when selecting reverse but that didn't do anything. Also to display the speed limit on the sat Nav but, again, that didn't work. I did also see a German video about changing the colour of the button icons but didn't have that option on mine either
lenko
Re: 2020 Mk4 Focus
Post by lenko »
Try this for speed sign in Navigation:
Navigation Speed Cameras 11-15MY APIM 7D0-02-02 xxx* xxxx xxxx, where "*" make 8=Disabled (Default), 0=Enabled. This was on a Ford Explorer spreadsheet.
Likely the same in newer vehicle. Note what the original number is so you can revert if it doesn't work.
davetcollection
Re: 2020 Mk4 Focus
Cortinaman wrote:
Tue Jul 20, 2021 9:08 pm
Mirror tilt only works on vehicles with memory seat I'm afraid
JRCondat
Vehicle: Focus SW MK4 2.0 TDCI 150cv, 2019
Re: 2020 Mk4 Focus
Post by JRCondat »
The Focus MK4 isn't fully compatible with Forscan :cry: :cry: :cry:
