GEM Error
ASB77
Vehicle: F250, V10 6.8, 1999
GEM Error
Post by ASB77 » Wed Jun 13, 2018 1:42 pm
I have a 99 f250 XLT with code B2141. The cause appears to be with the configuration of the GEM module. The only things it shows are the tire size and axle ratio, and the values of both are listed as error. I have tried to change them but part way through I get the message "writing blocks failed, incomplete configuration." My guess is that there is a problem with the as built configuration, Has anyone had experience with this? If this sounds like the problem how do I correct it.
