2018 Escape SE APIM
kb1dvg
Vehicle: 2018 Ford Escape SE
2018 Escape SE APIM
Post by kb1dvg » Wed May 16, 2018 4:51 pm
My 18 SE came without Navi & I ordered a new APIM from the dealer (Couldn't find a used one) & should be here soon. I played around with FORScan a little bit but never made any changes. What are the values that need to be changed to activate Navi? Here's what I currently see (sorry had to crop to get uploaded) (Under the APIM Module Configuration). Also there's been a mention about Climate displayed in the screen but hidden. How can I make it active on this one just to play around or is that dependent on the vehicle options?
Any & All help would be appreciated.
reachasiri
Vehicle: Escape 2014 Titanium
Re: 2018 Escape SE APIM
Post by reachasiri » Mon Jun 04, 2018 1:07 am
If you're still interested
https://youtu.be/KXZgSOOu87I
This video will be helpful..
Vladsky
Vehicle: '15 3.5L Eco-Borscht - 409 rwhp, 526 rwtq
Post by Vladsky » Tue Jun 05, 2018 3:45 pm
reachasiri wrote:If you're still interested
No - that video is NOT helpful. The OP has Sync3 - the vid applies to Sync2. :roll:
Vlad
twisterrescue
Vehicle: 2003escapeltd
Post by twisterrescue » Thu Jun 07, 2018 1:19 am
7D-01-02 xxxx x2xx xxxx nav 7D- 01-01 xxxx xxx6 xxxx single zone wo/hd radio GOOD LUCK use your original apim SAVED FILE !!! modify only these two lines!
twisterrescue
Post by twisterrescue » Thu Jun 07, 2018 1:26 am
correction to last post add nav 7D-01-02 x2xx-xxxx-xxxx wrong group last post!!!!!!!!!!!!
kb1dvg
Post by kb1dvg » Wed Jun 13, 2018 6:57 pm
Still Nodda?
twisterrescue
Post by twisterrescue » Wed Jun 13, 2018 10:00 pm
I hope that you did not use your VIN# . to order new APIM from dealer as they order thru ford by vin# as built .sync 3 apim ,s are NOT nav programmable .the apim will be navigation or non navigation they will not interchange you can go back to wo/ nav from nav wo/ parts but to go uo to nav
kb1dvg
Post by kb1dvg » Sat Jun 16, 2018 9:34 pm
Used Vin from one with it so it'll work.
