ABS and Traction Control Fault after Replacing Battery
Postby arslan.hamid » Sat May 12, 2018 1:23 pm
Hi people,
I replaced my positive battery terminal connector (circuit breaker assembly) on Explorer 2012 XLT after it got corroded. After starting the car, I got ABS related fault lights such as parking brake, ABS and traction control. Using forscan, I got the code U3000-41AB checksum failure on ABS.
Tried to clear this using forscan but the error persists. The brakes work fine, ABS also engages fine.
Please guys help me out on how to fix this?
arslan.hamid
Vehicle: Ford Explorer XLT 2012, 3.5L
Re: ABS and Traction Control Fault after Replacing Battery
Postby arslan.hamid » Sat May 12, 2018 3:00 pm
Bump
arslan.hamid
Postby MJRVR » Sat May 12, 2018 5:19 pm
Double check your connections that you touched.
MJRVR
Vehicle: ford fiesta 1.6 tdci 2006
Postby arslan.hamid » Mon May 14, 2018 6:09 pm
Update: Issue got solved after I performed a module reset and calibration on Forscan.
Thanks to the developers of Forscan!
arslan.hamid
Return to Diagnostics and Maintenance using FORScan
Who is online
Users browsing this forum: No registered users and 2 guests
