Bluetooth Issue after Sync 2 to 3 upgrade
Postby holmes114 » Tue Apr 17, 2018 2:45 pm
I recently did the Sync 2 to 3 upgrade in my 2013 Ford Edge. I've got everything programmed and working normally via FORScan with the APIM, but I've lost the Bluetooth option in the "Entertainment" field on the instrument panel. Now it only lists AM, FM and CD, no Bluetooth. Bluetooth works and plays fine, I've just lost the ability to switch to Bluetooth using the steering wheel controls now.
Does anyone know if this is something I can fix with FORScan, and if so, how? Or have I just lost that option with the upgrade?
holmes114
Vehicle: 2013 Ford Edge 3.5
Re: Bluetooth Issue after Sync 2 to 3 upgrade
Postby onedownfiveup » Tue Apr 17, 2018 5:23 pm
I have a question that has nothing to do with your question.
When "programming" your Sync 3 APIM is all you do is download AsBuilt back up based on your Vin and adding all those values to that new APIM?
onedownfiveup
Vehicle: 2016 Ford Explorer
Return to Configuration and Programming
Who is online
Users browsing this forum: No registered users and 4 guests
