reset to factory default in forscan
Postby pbpatel1981 » Thu Apr 05, 2018 3:03 am
i made a mistake not backing up...and i need to reset couple of things how do i do it?
i try to remove dual ac control from the sync 3 screen.
also trying to remove theme and put the original one back.
2016 f150 XLT sports
pbpatel1981
Vehicle: 2016 f150 XLT ECO boost
Re: reset to factory default in forscan
Postby wellzyseven » Sun Apr 08, 2018 2:46 pm
Which modules did you change? I have a 2016 Lariat with SYNC 3 and I can tell you what my factory settings are. No guarantees on if this will 100% fix your problem but it's worth a shot. Backup if you fix the problem!
wellzyseven
Vehicle: F150, 5.0L V8, 2016
Postby cbrannam » Wed May 16, 2018 10:34 pm
Can I get your back up file. you have the same truck as me. I did a back up but can't find it.
thanks
Cbrannam1@gmail.com
cbrannam
Vehicle: 2016 F150 6foot bed
Postby Vladsky » Wed May 16, 2018 11:04 pm
cbrannam wrote:Can I get your back up file. you have the same truck as me. I did a back up but can't find it.
thanks
Cbrannam1@gmail.com
NOT a good idea. At ALL.
Obtain YOUR VIN-Specific data: viewtopic.php?f=16&t=4393 ITEM #4.
Lastly - make a Test backup of a module. Go find where you stored it. Write that info down. For next time. :roll:
Vlad
Vladsky
Vehicle: '15 3.5L Eco-Borscht - 409 rwhp, 526 rwtq
Who is online
Users browsing this forum: Baidu [Spider] and 5 guests
cron
