Post by FORScan » Fri Mar 30, 2018 9:52 am
1. Protocols
Table 1.1 - Ford protocols
OBDII name / Ford name OBDII jack pinsBus speedBus min. response timeHow to detect
SAE J1850 PWM / Ford SCP2, 1041600 bps20...40 msImage
ISO9141 / Ford ISO79600 bps150...250 msImage
CAN / Ford HS CAN6, 14500 Kbps0...20 msImage
/ Ford MS-CAN3, 11500 Kbps0...20 msImage
/ Ford UBP310400 bps150...250 msImage
P - primary protocol (PCM)
GenerationSAE J1850 PWMISO 9141CANFord MS CANFord UBPComment
Ford 1996 - 2003PS---
Mazda 1996 - 2003-P---Some models used SAE J1850 PWM as primary
Ford EU, Mazda 2004 - 2009-SPS-Some models used SAE J1850 PWM as primary
Ford NA 2004 - 2009-SPSS
Ford, Mazda 2010+--PS-HS2, HS3 through MS-CAN
Focus Mk2 - only HS-CAN and MS-CAN
Mondeo Mk3 after restyling - J1850, ISO9141, HS-CAN, MS-CAN
ChipSAE J1850 PWMISO 9141CANFord MS CANFord UBPAdapter
ELM327 standardXXX--ELM327, Kiwi 3
ELM327 with HS/MS switchXXXX-ELM327 marked as Ford, Mazda compatible
STN 1100XXX--OBDLink SX/LX
STN 1150XXXX-OBDLink MX BT
STN 1170XXXX-ELS27 (old versions), Viaken STN1170
STN 2120XXXX-ELS27 (new version)
2. Performance
AdapterChipInterfaceMin.interface
response time
Max.interface
baud rate
Comment
ELM327 OHP HS/MS WiFiELM327 (clone)WiFi30-40 ms38400 bpsUnknown manufacturer - "good clone". Recommended only for iOS
Kiwi 3ELM327 compatibleBluetooth Low Energy40 ms-Can be used only with FORScan Lite for iOS
ELM327 HS/MS USBELM327 (original)USB0..2 ms500 Kbps
OBDLink SXSTN1100USB0..2 ms500 Kbps
OBDLink LXSTN1100Bluetooth--
OBDLink MX BTSTN1150Bluetooth8..20 ms115200 bps
OBDLink MX WiFiSTN1150WiFi-115200 bpsWiFi interface works unstable - it freezes and times out. Strongly not recommended!
ELS27 v3STN2120USB, Bluetooth0..2 ms USB,
20 ms BT
8 Mpbs USB
Viaken STN1170 USBSTN1170USB0..2 ms2 Mbps
Viaken STN1170 BTSTN1170Bluetooth20..30 ms38400 bpsMay freeze on some cars. Not recommended
Examples:
Example 1: Ford Mondeo Mk3 PCM, bus J1850. Adapter ELM327 OHP HS/MS WiFi. According to the table 1.1, let's assume min. bus response time is 20 ms, bus baud rate is 41600 bps. According to the table 2.1 adapter's min response time is 40 ms, baud rate is 38400 bps.
Overal min.response time = 40 ms + 20 ms = 60 ms
Overal baud rate = MIN ( 38400 / 2, 41600) = MIN ( 19200, 41600) = 19200 bps.
Note: we divide interface baud rate by two because ELM327 family adapters exchange data in text format. So every machine byte is represented in 2 transferred bytes.
As we can see, the adapter significantly limits the overal system peformance in this example (in case of cars with CAN bus, like Mondeo Mk4 or Mk5, the test results would be much worse). Is that bad? Well, it depends on your goals. If reading DTC and some PIDs is the only objective you have, it is not too important. But if you plan to read PIDs in real-time (or as much close to it as possible) or perform programming (actual for CAN bus), then this adapter is a bad choice.
Example 2: Mazda 323 2001, bus ISO. Same adapter.
Overal min.response time = 40 ms + 250 ms = 290 ms
Overal baud rate = MIN ( 38400 / 2, 9600) = MIN ( 19200, 9600) = 9600 Kbps.
In this case the adapter is OK, because the bus itself is very slow. Reponse time is less than 20% higher than maximum possible for this car, and transfer speed is also limited by the bus.
Example 3: Ford Fusion 2015, bus CAN. Adapter ELS27 v3 USB. Let's assume CAN bus response time is 0 ms, and adapter has 2 ms of response time and 2 Mpbs baud rate.
Overal min.response time = 2 ms + 0 ms = 2 ms
Overal baud rate = MIN ( 2000000 / 2, 500000) = MIN ( 1000000, 500000) = 500 Kbps.
So in this case the response time is minimal, and baud rate is limtied by the CAN bus one.
3. Reliability
4. Recommendations
P - recommended for programmign: complex configuration, firmware update (only for CAN )
AdapterFORScan for WindowsFORScan Lite for iOSFORScan Lite for Android
ELM327 OHP HS/MS WiFi (clone)NODNO
Kiwi 3NOD (if MS-CAN is not required)NO
ELM327 HS/MS USBD, C, PNONO
OBDLink SXD, C, P (if MS-CAN is not required)NONO
OBDLink LXD (if MS-CAN is not required)NOD (if MS-CAN is not required)
OBDLink MX BTD, CNOD
OBDLink MX WiFiNONONO
ELS27 v3D, C, PNOD
Viaken STN1170 USBD, C, PNONO
Viaken STN1170 BTNONONO
5. Links to original adapters
All of these adapters were tested by us
5.1. ELM327 HS/MS USB: http://elm-327.eu/
Update 2018-05-11. Note: this company also sells standard ELM327 BT (without HS/MS switch) that may NOT work properly with some models as Bluetooth chip may freeze on requests that receive a lot of data (same problem as in Viaken BT described above).
5.2. Kiwi 3: https://www.plxdevices.com/ . Note: this adapter is only supported by FORScan Lite for IOS! FORScan for Windows and FORScan Lite for Android have no support for this adapter.
5.3 ELS27: http://els27.ru
5.4. OBDLink product line: https://www.scantool.net/
5.5. Viaken: https://viaken.pl/pl/polski-elm327-v3-f ... -2014.html
6. Links to other adapters
6.1. Elm327 HS/MS OHP good clone: https://www.amazon.com/OHP-Forscan-comp ... Ford+Mazda
It not original, but there is no better alternative for FORScan Lite for iOS yet.
dickiefrank
Vehicle: 2103 Ford F150 STX 5.0
Post by dickiefrank » Sun Jun 03, 2018 1:42 am
I'm getting a reading on the forscan when I try to link it to the truck...says "bad clone"...my connector does not have the toggle switch...am I to conclude that I need the one WITH that toggle switch?
Vladsky
Vehicle: '15 3.5L Eco-Borscht - 409 rwhp, 526 rwtq
Post by Vladsky » Sun Jun 03, 2018 12:22 pm
dickiefrank wrote:I'm getting a reading on the forscan when I try to link it to the truck...says "bad clone"...my connector does not have the toggle switch...am I to conclude that I need the one WITH that toggle switch?
The proper adapter you need is already specified above.
Suggest you start reading, Dickie :lol:
Vlad
nixoid
Vehicle: Ford Ranger, 4.0 liter, 2003
Post by nixoid » Sat Jun 09, 2018 4:13 am
Vlad
I haven't looked at too many threads yet but every post I've seen from you has the voice of a troll. Instead of just telling people to read like they're stupid or lazy, try helping out. Not everyone can understand technical info as well as you.
