Add climate control to IPC on 2014 Explorer Limited
toast1850
Vehicle: Explorer, 3.5L V6 2014
Post by toast1850 » Fri Jul 28, 2017 4:49 pm
Does anyone know if it's possible to add the climate control setting in the bottom right screen of the 4.2" cluster? I've read on these forums that some have been successful on the 2016 model.
I also know that the 2013 model Explorers had the climate control enabled from factory.
Any help would be greatly appreciated.
I have also attached an image for reference.
Explorer climate control
Climate and Temp.jpg (38.03 KiB) Viewed 9914 times
Mustang5L5
Vehicle: 2014 Ford Taurus 3.5L FWD
Re: Add climate control to IPC on 2014 Explorer Limited
Post by Mustang5L5 » Fri Sep 08, 2017 1:03 am
Bump.
Would like to add this to my '14 Taurus Limited as well. Looks like it was on the '13 models, and ford removed it for '14 for some reason
toast1850
Post by toast1850 » Mon Sep 11, 2017 4:09 pm
Does anyone have any valuable feedback or info on this? There has to be a way it can be enabled.
marobrown
Vehicle: 2016 SHO 3.5L EB, 2017 Superduty 6.2L 3.73
Post by marobrown » Sun Sep 17, 2017 2:24 pm
I was also unable to do this on my 2016 Taurus
toast1850
Post by toast1850 » Fri Oct 06, 2017 3:51 pm
This is really disappointing. Hopefully someone can figure this out and kindly post.
konnyjjuang
Vehicle: Ford Explorer 2017
Post by konnyjjuang » Tue Nov 07, 2017 1:57 am
I wish this problem will be solved.
I tried to add climate control, but I couldn't see that picture.
Entertaintment was disappeared.
I have 2017 Explorer.
Medic1592
Vehicle: Explorer, 3.5L GTDI, 2017
Post by Medic1592 » Thu Dec 14, 2017 9:59 pm
On the 2017 explorer to get all 4 menus (Nav, Climate, Phone and entertainment) the FORScan code is:
IPC 720-05-01 XXBX XXXX XXzz
The spreadsheet has an 8, but that removes the other menus. Place the letter B instead, it gave me all four.
toast1850
Post by toast1850 » Fri Feb 16, 2018 9:17 pm
Hi Medic1592,
The 2014 Explorer doesn't have a 720-05-01 option. It ends at 720-04-02. Nothing I have changed has added the climate. Maybe it's not possible. It's odd that previous gen Explorers had this enabled from the factory.
NavigatorV8
Vehicle: Mondeo MK4
Post by NavigatorV8 » Mon Jun 11, 2018 10:02 pm
toast1850 wrote:Hi Medic1592,
The same at mine Explorer. Anybody found a solution?
mbalmhmd
Vehicle: Mustang 3.7 2015
Post by mbalmhmd » Tue Jun 12, 2018 4:17 am
Hello guys
I broud you 2011 Explorer VIN has Climate control on dash. Hope someone will finger out the right code to activate’t for us
1FMHK8D88BGA74333
