Problem with ABS
Problem with ABS
Postby Hektorian » Fri Dec 30, 2016 7:41 am
Need help to fix problem I have with ABS module on Ford Focus 2.0 Tdci year 2015. Yesterday I went to official service for oil change and replacement of the TPMS what was broken by tire repair workshop, when I changed to winter tires. Official service didn’t had replacement sensor and told to come back in few days, even when I told them that I have this problem few days before, when I scheduled visit. I got angry and decided to turn deflation monitor OFF by Focccus software. During procedure communication between PC and car crashed several times before it was successfull. I managed to turn OFF deflation monitoring, but new problem came up. ABS module and dashboard control light, was giving me error code U2300 Invalid/Incompatible Configuration and BCMi module error U2101. I found on the net that with Focccus I should solve this problem with re-initialization of the ABS module. I tried it, warning light for ABS on dashboard blinks during procedure, but after finish I still have same error and new one Not programmed. This last one I can reset using Forscan.
If anyone have any idea how to resolve this problem, or I need to visit official service again. Below I attached print screens of errors…
Thanks for the help in advance!
ABS error 1.png (178.6 KiB) Viewed 730 times
ABS error 2.png (184.94 KiB) Viewed 730 times
BMCii error.png (133.95 KiB) Viewed 730 times
Foccus reinit.png (46 KiB) Viewed 730 times
Hektorian
Vehicle: Ford Focus 2.0 TDCi, 2015
Re: Problem with ABS
Postby jeroenbreuer » Wed Apr 11, 2018 7:59 pm
Is there a sollution for this issue?
My car has the same problem.
jeroenbreuer
Vehicle: Focus MK3 1.6tdci econetic ‘13
Postby f-wolf » Wed Apr 11, 2018 8:59 pm
This is what I found:
Problem U 2300-56.jpg (47.57 KiB) Viewed 121 times
See bottom of Page 30
Download this PDF
http://ww2.justanswer.com/uploads/HE/he ... us_bcm.pdf
Also have a look here: https://www.ucdsys.ru/forum/viewtopic.php?f=29&t=513
f-wolf
Postby jeroenbreuer » Thu Apr 12, 2018 10:49 am
For me, I put my car ‘back’ with the As-built file. Problem solved.
jeroenbreuer
Return to Diagnostics and Maintenance using FORScan
Who is online
Users browsing this forum: No registered users and 6 guests
