2012 Explorer Airbag Light Code B1212:13-8F
Postby arslan.hamid » Wed Oct 12, 2016 9:32 am
Hi guys,
Airbag light stays ON on my Explorer 2012 XLT. Checked it out using FORScan, got code B1212:13-8F.
B1212 means driver side buckle pretensioner, while the 13 means the circuit if open. Wondering what the "8F" indicates. Does it point to a specific connector or harness on the circuit? I understand there are 3 connectors on this circuit - C3065, C210 and C310.
PID Deploy_18_R indicates 4 ohm resistances, which is out of 2.87 threshold. I need to diagnose the connector having the "open" circuit.
I read somewhere about opening each connector and jumping the pretensioner pins. Should this be done while the vehicle is running?
Anyone with practical experience, please help!
arslan.hamid
Vehicle: Ford Explorer XLT 2012, 3.5L
Re: 2012 Explorer Airbag Light Code B1212:13-8F
Postby blueoval24 » Tue Nov 15, 2016 6:26 pm
arslan.hamid,
Before taking the step to jump connectors, have you been able to physically verify that all the pins are seated in their proper connector? I only mention this because I bought my Explorer used, and upon inspecting the reconditioning report, it appeared that I had the same trouble code as you (B1212). In my case, the technician found a loose connection at connector C210, which resolved the error code completely. Attached is a snapshot of that portion of the reconditioning report. If you need locations and views of the connectors, let me know, Im sure I can dig them up in my Ford shop DVD. Hope this helps!
https://drive.google.com/file/d/0B_7wxS ... sp=sharing
blueoval24
Vehicle: 2012 Ford Explorer
Postby wujekt » Sun May 13, 2018 6:50 pm
blueoval24 wrote:arslan.hamid,
Hi, I got the same problem code B1212. Could you please to send view and location of the connectors? Thank You
wujekt
Vehicle: Ford Explorer 3.5L XLT 2011
Return to Diagnostics and Maintenance using FORScan
Who is online
Users browsing this forum: No registered users and 4 guests
