Postby FORScan » Tue Jan 06, 2015 3:26 pm
In the 2.2.* branch we introduce new terms: Standard License and Extended License for Windows versions of FORScan.
Standard license is the default one distributed with FORScan. Anyone who has downloaded and installed FORScan version for Windows works under Standard license. FORScan under Standard license is fully functional, except some (few) functions that are available under Extended license only. Extended license is not provided by default and has to be obtained as described below.
The objectives of the Extended license:
1. Limit access to critical functions. For example, let's look at the PATS programming functions. If the function is available without any control, any thief who has a laptop and ELM327 can program new key just for seconds. We do not think this is something what our users want.
2. Take payment for functions that are most time/resource consuming in impementation. We are often asked about donation. We have no donation scheme, but in the future anyone who wish to help us financially has an ability to purchase the Extended license.
So in other words, if you are a FORScan user, you will have only 2 cases when you need the Extended license:
A. If you want to help to FORScan team financially (in the future, as currently we have no payment options).
B. If you need an access to a function that is available under Extended license. If it is your case, please do not try to inquire for Extended License unless you see the following message:
List of functions that require Extended license:
Note: the functions may be implemented not for all models. Please either check for your car support in Change Log on the Download page, or check for the function presence in the functions' list when FORScan is connected to the vehicle,
Service -> PATS Programming
Configuration and Programming -> Module Configuration
Configuration and Programming -> Module Configuration(AS BUILT format)
Configuration and Programming -> Central Configuration
Configuration and Programming -> Module Reset/Configuration (required to learn central configuration changes related to these modules)
All the rest functions do not require an Extended License!
How to get the extended license:
1. Copy the Hardware Id from the About chapter of FORScan:
Important note: you need the hardware id of the equipment that directly works with your vehicle. So if you have a desktop and laptop, and you use the desktop to review the logs and the laptop is used to connect to your vehicle, you need to get the Hardware Id of you laptop!
2. Generate trial license using this link:
with the following information:
- Your First and Last name
- Contact phone
- Hardware Id obtained in the item #1
3. After license key is successfully generated, click on the Download link in the Action row of the table and download the license key to any convenient place.
4. You have 2 ways to apply the license key:
4.1. Just double-click on the file and confirm adding the registry record, then restart FORScan.
4.2. Use button Load license key in FORScan->About section, then agree to restart the application.
5. FORScan with correctly applied extended license should look like this:
Postby Tman » Fri Feb 20, 2015 9:45 am
Hi where do I email my details to please ?
Tman
Vehicle: Transit mk6 2.0di
Postby FORScan » Sun Feb 22, 2015 10:39 am
Tman wrote:Hi where do I email my details to please ?
You can send them using PM on this forum, or using a email address on Contact Us page on this site.
Postby tzok » Mon May 11, 2015 5:36 pm
Beta-testers, translators and all the other people who helped us with the project R&D can get the lifelong Extended license, following the procedure below.
I have applied for the Extended License, but get only 3 month Trial license. According to what you said, as a translator (PL), I should have received a lifelong license.
tzok
Vehicle: Fiat Grande Punto
Postby FORScan » Tue May 12, 2015 4:39 am
You must be in special Translators or Testers group in order to obtain lifelong license key this way, adding to these groups doesn't happen automatically but by request. We have added you to the Translators, you can now try to re-generate the key.
Postby simpsonrl » Thu May 14, 2015 6:52 pm
Hi Forscan,
I see the extended license is good for 2 months. After it expires, can it be re-applied for and another one gotten? I am modifing a PCM and Engine from a wrecking yard to work in a boat. I will need to get into the PATS system since I did not get original keys. Also, is there a list of which modules require the extended license to be able to access?
thank you!
Bob
simpsonrl
Vehicle: 2001 F-150 5.4L
Postby tzok » Thu May 14, 2015 9:14 pm
FORScan wrote:you can now try to re-generate the key.
Thank you, but how can I drop the trial license to generate a new one? I've tried uninstalling and reinstalling the program but it didn't work.
tzok
Postby FORScan » Fri May 15, 2015 3:00 am
You need to generate the license and download it to PC, then open the *.key file using Windows Explorere or any other file commander. Confirm adding record to the registry. New key will replace old one.
Postby poochini2009 » Tue Jun 23, 2015 9:23 pm
Hi all, if a license for 10 days is possible to see the functions available in the full version of Forscan .
I am 327 ELM 1.4 interface with the two keys as illustrated , I want to see the function set injectors because I do not have a scanner for that service.
Best Regards.
Email: microelectronica@arnet.com.ar
poochini2009
Vehicle: FORD ECOSPORT AÑO 2010
Postby FORScan » Wed Jun 24, 2015 2:14 am
You should be able to program injectors without Extended License, if FORScan does support it. Extended license (at this moment) is necessary only for PATS function programming. Also you can get it for free for 2 months at least, see first post of this thread.
Next
Who is online
Users browsing this forum: No registered users and 5 guests
