FORScan release notes
Re: FORScan release notes
Postby lollapalooza » Thu Oct 13, 2016 4:25 pm
DeclanJewell wrote:Can anybody help me here in accessing the config files?
Cheers in advance
Your question is already answered. Just read a few messages above yours.
lollapalooza
Postby MarcoGaspar » Fri Nov 18, 2016 8:58 pm
Trying to use Central Configuration on Mondeo 1.8 TDCI 2008 but getting error:
(OK) [21:08:58.283] Central configuration (Main) has been started
(WARN) [21:08:58.317] Read configuration from primary module...
(WARN) [21:09:07.022] Loading SBL to primary module...
(WARN) [21:09:07.305] Loading block 1/4...
(WARN) [21:09:27.596] Loading block 2/4...
(WARN) [21:09:27.981] Loading block 3/4...
(WARN) [21:09:28.325] Loading block 4/4...
(OK) [21:09:28.892] SBL loaded successfully
(OK) [21:09:29.137] Read block #1
(OK) [21:09:29.288] Read block #2
(OK) [21:09:30.009] Read block #3
(OK) [21:09:30.127] Read block #4
(ERR) [21:09:31.395] Reading block 5 failed
(ERR) [21:09:31.418] Service procedure has been interrupted
Whats the problem?
Best Regards,
Marco Gaspar
MarcoGaspar
Vehicle: Ford Mondeo, 1.8tdci, 2008
Postby Yoko89 » Wed Mar 08, 2017 11:39 am
rioachim wrote:https://www.fordtechservice.dealerconnection.com/vdirs/wds/PCMReprogram/DSFM_PCMReprogram.asp?swproduct=IDS
I can't find calibration files for the cars i want
7m5t-14c088-aa
8v4t-14c088-aa
Yoko89
Vehicle: Fiesta 1.6 105hp 2014
FORScan release notes v2.3.8
Postby FORScan » Tue Mar 28, 2017 6:46 am
Version 2.3.8 has 2 quite important functions added:
1. Built-in outcode-incode generator for pre-2011 vehicles with coded PATS. Now it is not necessary to use an outside outcode-incode generator that was often inconvenient. Corresponding article is updated: viewtopic.php?f=6&t=839
2. Ability to read parameters (PIDs) from several modules simultaneously. New article is created to explain it: viewtopic.php?f=6&t=3334
Postby cckst » Tue Apr 11, 2017 12:01 pm
Hi, may I have ask question about the new version.
When the new version support Mazda year 2017 model?
Today I had try to connect Forscan 2.3.8 to Mazda Demio 2017. But There is pop up window which talking about unknow PCM.
This version is working fine in model 2014-2016. Kindly advise. Thank you
cckst
Vehicle: Mazda DEMIO 2016
Postby bizkitt » Tue Apr 11, 2017 8:58 pm
Same exact issue as MarcoGaspar... Reading block 5 failed on a 07 Mondeo 2.0 TDCI, guys correct me if i`m wrong... do you need to load SBL to read the CCF form BCM? i dont think so.. you can read it by pid just send "22F105" read 512bytes from "0x00FF8000 to 0x00FF81FF" than after editing before sending it back divide it into the 5 blocks like :
1st block 0x00FF8000 to 0x00FF8057
2nd ........
3rd ........
4th ........
5th ........
proceed and send it back to BCM like:
1000x of 10 82`s :D + 27 01 Pass security, load SBL + activate it, erase + flash blocks and end it with a reset 11 81...
if the right person sees what i wrote here will PM me i might be able to help...
bizkitt
Vehicle: Mondeo MK4, 2.0 TDCI, 138hp, 2007
Postby maxbe » Tue May 02, 2017 6:59 pm
Can I expect pats support for Mazda 6 GH 2008 euro diesel?
Regards
maxbe
Vehicle: 6 gh 2008 diesel
Re: FORScan release notes v2.3.8
Postby margut » Sat May 06, 2017 9:52 am
FORScan wrote:Version 2.3.8 has 2 quite important functions added:
I installed this version on top of 2.3.6 which I used to connect in 2008 Escape L3 2.3L Gene. Export. Previous version 2.3.6 can read all modules however this version cannot read Instrument Cluster and ABS modules:
a. ABS Error "unable to read DTC,
b. Instrument Cluster U1900 "Missing the CAN message from the PCM".
What could be wrong? I reboot pc in Win 7 32Bit but still the same. Now I reverted back to 2.3.6 version...
margut
Vehicle: Escape, L3 2.3L 2008
Postby Cellular-Decay » Wed May 10, 2017 7:35 am
Any plans to support PATS on cars with Advanced Keyless Entry and start?
I have a 2011 Mazda MX5/Miata with AKE and got the following message when trying to access PATS.
I'd be happy to help with this if you need any info from my car, or testing new features.
They key programming should be the same for AKE cars, as they use the same transponder engine immobiliser system with the auxiliary key. It would be nice to at least get key programming working. If we could also get AKE remote/FOB programming that would be outstanding!
Cellular-Decay
Vehicle: Mazda MX-5 2.0L 2011 (GT PRHT)
Postby Maraas » Sun May 14, 2017 8:46 pm
Same issue here.
MarcoGaspar wrote:Hello,
Whats the problem?
Best Regards,
Marco Gaspar
Maraas
Vehicle: Ford Mondeo 2.0 TDCI 140KM 2007
PreviousNext
Who is online
Users browsing this forum: Baidu [Spider], Google [Bot], hsieh and 8 guests
