DPF Soot Loading
TomsFocus
Vehicle: 2012 Focus 1.6 TDCi 115ps
DPF Soot Loading
Post by TomsFocus » Tue Feb 13, 2018 12:53 pm
Can anyone tell me the difference between the 'closed' and 'open' soot loading percentages on FORScan and what a good ball park percentage would be for 40k miles?
Mk3 DPF parameters.jpg (102.04 KiB) Viewed 883 times
I've recently bought a Mk3 1.6TDCi Focus but with the lowish mileage for year want to make sure the DPF is ok. Seems to be very little pressure differential but I'm not sure if I should be worried about the 57% soot loading there?
Also, possibly unrelated but the engine is very jerky when cold - EGR, MAF and temp sensors all seem to be working ok. There is a PCM update available but I'm trying to rule out any faults before having that done so is there anything else you'd recommend checking?
Tom
denbo
Vehicle: ford focus 16 zetec
Re: DPF Soot Loading
Post by denbo » Tue Feb 13, 2018 7:55 pm
Yes you are correct, the soot load is too high. Take it for a long run and recheck. It might do a regen but this is a Peugot engine so don,t hold your breath. Do not do a static regen....at that % it could burn the car down. Much safer to get it cleaned.
TomsFocus
Post by TomsFocus » Sun Feb 25, 2018 3:04 pm
Does no-one know what the difference between the 2 soot loads is then? :?
I've since seen that it can go well above 100% on both if there's a fault, but still regen fine once the fault has been rectified so it looks like 57% isn't that bad.
Anyway, it seems to be regenerating fine despite my borderline mileage for a DPF, currently sitting at 2% and 19%, down from 10% and 57% when I first got the car. I'd still like to know what the difference between the 2 is though lol!
Mk3 DPF Parameters 3.jpg (77.25 KiB) Viewed 755 times
evrr82
Vehicle: Ford Kuga, SUV, 2.0TDi, 150hp, 2015
Post by evrr82 » Thu Mar 01, 2018 5:06 pm
I also noted those 2 parameters.
The only difference between them is Open and Closed Loop. The first one, "Closed Loop" might be an estimate of filter loading based on differential pressure using feedback from real sensor. "Inferred Open Loop" might be a backup estimate of filter loading based on something like fuel burnt, motor hours etc in case if data from sensor is unavailable.
However, that's only my guess.
Blinkston
Vehicle: Fiesta 1.4 TDCi 2002
Post by Blinkston » Fri Mar 09, 2018 6:56 am
On the cold running fault have you checked the glow plugs are working as I had the same issue on one of these.i had a plug fail and run very lumpy until it was warm
