How to use PATS Module Initialization function
Re: How to use PATS Module Initialization function
Postby fred08155 » Thu Feb 09, 2017 3:41 pm
As you can read in the first post there is no such function for your car.
Duratorq TDCI engines of the same models have no Module Initialization functions
This function exists for "Duratorq DI" engines only. I guess this means TDDI.
Postby smirnoffrules » Sat Apr 08, 2017 10:45 am
hi , does the new built in pats function work with this now ie twin numbers ? have a focus c-max to do next week and have to replace pcm , l take it l only need to do option 3 ? seems to have be down for awhile
Focus Mk2/CMax
Module initalization function is used here when instrument cluster (HEC or IC) and/or PCM module is replaced.
If HEC/IC or both HEC/IC + PCM are replaced, the following sequence of actions should be performed:
i. Erase all keys (Single coded or timed access have to be obtained)
ii. Program at least 2 new keys
iii. Do module initalization (Dual coded access may be required)
if only PCM is replaced, the steps (i) and (ii) are not necessary, and only step (iii) have to be executed.
Vehicle: ford c max 2007
Postby kilm » Sun Oct 08, 2017 4:31 pm
I have succesfuly replaced a Ford C Max 2003 EDC16C3 PCM with Forscan.
Thank you very much Forscan team for your work
Vehicle: Ford C Max, 1.6Tdci 110, 2008
Return to Diagnostics and Maintenance using FORScan
Who is online
Users browsing this forum: No registered users and 6 guests
