Carboncow
Vehicle: 2103 F150 3.5EB
Post by Carboncow » Tue Feb 13, 2018 8:39 pm
Windows XP Pro here...when I LOAD LICENSE KEY and set to *.key option the file is not visible under any circumstance...no matter what folder I try to put it in from MY DOCS to C:\
Any suggestions?
I know this system is old but it seems to work fine with FORScan, Vida-Dice and VCDS that I run it on...so I'd like to stay with it!
EDIT: Figured out. Although windows xp was showing xxx.key it was really named xxx.key.csv. I had to show "known extensions" and then rename from .csv to .key...all is good for temp extended lic.
denis.KO
Vehicle: ford fiesta 1,4 lpg 97cv 2012
Post by denis.KO » Sun Feb 18, 2018 7:40 pm
]buona sera !volevo chiedere se è possibile avere una licenza forscan indirizzo mail denis.kortoci@hotmail.com grazie!
lollapalooza
Post by lollapalooza » Mon Feb 19, 2018 7:13 am
denis.KO wrote:]buona sera !volevo chiedere se è possibile avere una licenza forscan indirizzo mail denis.kortoci@hotmail.com grazie!
Read the 1st post of this topic.
petersontr
Vehicle: F140, 2.7 Ecoboost, 2017
Post by petersontr » Fri Mar 02, 2018 3:56 am
I too am getting error below...please advise. I am attempting to enable trailer brake controller that I installed. Thanks in advance!
gundown64 wrote:Getting the below error:
Unable to generate license key. Please make sure Hardware ID is copied correctly
Is this system down? I noticed some people had problems a few days ago with the same error.
se9303
Vehicle: Ford Explorer 4.0L 2006
Post by se9303 » Mon Mar 05, 2018 10:44 pm
Greetings to all,
I have obtained the 2 month extended license but would like to obtain the lifetime license key as a translator or tester group category. Can you put that request is so my lifetime license key can be generated? Please advise how i can remove the temporary license and activate the lifetime license key once issued? Also, will i receive an email indicating this has been processed and how to proceed with the new key?
I have a 2006 Ford Explorer that was our daily driver and the instrument cluster/PCM went bad as diagnosed by the repair shop so i removed the instrument cluster/PCM from a project 2006 Explorer i purchased to fix later on and gave them to the mechanic so they could repair my daily driver vehicle. They fixed it but only coded 1 of the keys so now i need to code the remaining key and also have the extended license to work on my project Ford Explorer which will need an instrument cluster/PCM and keys programmed along with other issues to get it up and running hopefully
i did not know about this software until earlier today over at a ford explorer forum i was told about this. Great to know you guys are here!!! I do BMW coding/programming and will be starting to work on Ford vehicles so i will require the lifetime license.
Regards,
Mark
darkmic
Vehicle: Mondeo MK4 QXBA 2009
Post by darkmic » Wed Mar 07, 2018 3:54 pm
Hello, i've got a problem. I generate the extendet license but after loadi g it into Forscan and restarti g nothing happens. Trying to configure a GEM for a 2006 Fiesta. It keeps telling me i need extended license. generated it 2 times , hardware id is correct. Please help. I preffer working with Forscan& ELM327 because it's faster than IDS &VCM1/2 :))
Thank You
fordgabby
Vehicle: ford exlpore 3.5
Post by fordgabby » Mon Mar 12, 2018 12:00 pm
Please after installing the extended license the tool cannot connect or recognized any ford car connected.KINDLY help me because it was ok with the standard until i updated it to the extension license.Thanks.
wojciech0015
Vehicle: Mondeo MK5 2.0 Ecoboost 2013
Post by wojciech0015 » Mon Mar 12, 2018 1:14 pm
Hi Friends
I have a question. I have a Fusion 2013 USA 2.0 ecoboost, 240KM, and I receiced Forscan Licence for 2 months. How Can i buy lifetime licence ?
lollapalooza
Post by lollapalooza » Mon Mar 12, 2018 1:17 pm
wojciech0015 wrote:I have a question. I have a Fusion 2013 USA 2.0 ecoboost, 240KM, and I receiced Forscan Licence for 2 months. How Can i buy lifetime licence ?
You can't.
But it's not forbidded to apply for a new one, once your current license expires.
wojciech0015
Post by wojciech0015 » Mon Mar 12, 2018 1:25 pm
You can't.
Ok Thanks
