Lincoln MKS codes?
Lincoln MKS codes?
Postby b4black » Sun Apr 15, 2018 9:07 pm
I just bought a 2013 Lincoln MKS. I want to added the AWD and TPMS gauges to my instrument panel (IPC module).
I'm finding the codes in the internet are nothing like mine. So I assume the codes are not universal. But should I expect the Taurus codes to be the same as the MKS?
If I can't find the codes for the MKS online, I'm I out of luck?
b4black
Vehicle: 2013 Lincoln MKS 3.5 TT
Re: Lincoln MKS codes?
Postby b4black » Wed Apr 18, 2018 9:45 pm
I found some SHO codes, but they are not the same.
This is what I get when I look at the IPC mocule. Any suggestions?
Forscan IPC.png (8.1 KiB) Viewed 225 times
b4black
Postby b4black » Mon Apr 30, 2018 6:13 pm
OK, the MKS and Taurus are similar. The MKS is pretty loaded to begin with, so there's not much left to enable.
Looking at 720-01-02, changing the first 8 to a B made the Intelligent AWD gauge appear in the left pod. Neat, but I'm not sure how useful it is.
I would like to figure out how to display TPMS reading, but it may not be possible on the Taurus/MKS. I'd also like to figure out how to display the transmission gear at all times.
b4black
Postby sleepy » Fri May 04, 2018 12:48 am
How much does it cost now?
sleepy
Vehicle: Mazda CX 5 2,5 2014
Postby denbo » Fri May 04, 2018 5:04 pm
SLEEPY, stop jumping onto threads, If you have a question then start a new post or we call you DOZY
denbo
Vehicle: ford focus 16 zetec
Return to General and Support forum
Who is online
Users browsing this forum: camcmul73, fgservo, markanth0ny and 4 guests
