Can't find modules in Forscan. *Fixed*
Schwartzpeter
Vehicle: Ford Focus 1,6 tdci 2007
Post by Schwartzpeter » Mon Feb 12, 2018 6:26 pm
Hello.
When i open forscan and do a scan the only moduls that comes up are PCM and OBDII. Its like it doesnt show ms/can.
Vehicle: Ford Focus MKII, 1,6 tdci 2007.
Connection: ELM327 v1.5 copy from china.
And BTW the faults that shows for PCM are:
P2458 - PDF regulation duration.
P1412 - EGR valve frozen.
Is there somewhere i can look these fault codes up to see some known issiues?
ricdan
Vehicle: Falcon AUIII, 6cyl 4.0L,2002
Re: Help to forscan
Post by ricdan » Fri Feb 16, 2018 9:27 pm
Just brand new to this myself but I've been seeing a few similar issues as I hunt around for information and it seems that some units are shipped with an m/s switch and some without. Mine has the switch and on Forscan I have been leaving the switch in one position and using the "auto" function under the heading "ELM327 specific" in the "connection" tab -- I'm not even sure if that's the best approach yet but maybe that will give you somewhere to look.
Schwartzpeter
Re: Help to forscan
Post by Schwartzpeter » Tue Mar 13, 2018 7:05 pm
Yeah i shearched a lot my self and found the same issue. I have regular now without the switch and have ordered one with a switch a couple days ago. I hope that will be it.
Thanks for the reply
Schwartzpeter
Re: Help to forscan
Post by Schwartzpeter » Fri Apr 27, 2018 6:17 pm
**Update**
Bought a cheap ELM327 with a switch which helped i can now see more moduels.
joffy01582
Vehicle: fiesta petrol 1.6
Re: Can't find modules in Forscan. *Fixed*
Post by joffy01582 » Sat Apr 28, 2018 1:14 pm
i can see modules but cannot enter any changes using the windows beta download and extened license :?:
joffy01582
Post by joffy01582 » Sat Apr 28, 2018 4:48 pm
Sorted now after playing a little bit... Now I have my sony dab radio playing in my fiesta mk7 2010
