2015 Ford edge want to install navigation
Fordsrule5000
Vehicle: 20115 Ford Edge 2.o ecoboost Titanium
Post by Fordsrule5000 » Sat Feb 03, 2018 10:14 pm
Hello I am interested in putting navigation in a 2015 ford edge titanium that does not have navigation on my ford touch!
I have the OBd2 elm 327 and FORScan. I am pretty techy just need to know what hexadecimal numbers or letters to change to do this if anyone can help I’d appreciate it.
twisterrescue
Vehicle: 2003escapeltd
Re: 2015 Ford edge want to install navigation
Post by twisterrescue » Wed Feb 07, 2018 9:58 pm
YOU can not do it .but if you read 1000 post like I did you can update your sync sys to 3.08 update then find the png wallpaper file then change the required 7d01-02 line of code w/FORscan then buy a ford sd card a-8 map it will work DO NOT attempt to update your sync sys thru syncmyride.com they closed the loophole for the navunlock png wallpaper
timburon
Vehicle: Ford Edge, 6 cyl, 2012
Post by timburon » Thu Feb 08, 2018 1:40 pm
Sorry, just for clarification. I was planning on doing this following (as you point out) the many threads telling how to do it, but your last line threw me. My MFT is updated to 3.08 through syncmyride, a while ago. Does that mean I will not be able to turn on navigation? I don't want to buy an A-8 only to find out it no longer works. Can you explain the line "DO NOT attempt to update your sync sys thru syncmyride.com they closed the loophole for the navunlock png wallpaper"? It'll save me the cost of the sd card if I'm reading it right.
rferrer100
Vehicle: 2015 Ford F-150 XLT
Post by rferrer100 » Tue Feb 13, 2018 1:19 pm
I'm trying to do the same thing with myfordtouch except I have a 2015 F-150. I do want to install nav as well. I'm confused with "timburon". I don't want to attempt it and purchase the cable if it doesn't work. Do I also have to purchase the navigation SD card from ford?
twisterrescue
Post by twisterrescue » Thu Feb 22, 2018 9:08 pm
sorry for the late replys guys mft sync 3.08 will work using the PNG image on forums FORD sync my ride is now above that firmware .and the open window is closed .find like I did 3.08 update no higher! unzip copy to a stick 4 gig or higher size .put in usb port it will self load .it takes about 45 minutes car must be running ! (battery saver will shut down if not running!) then find the PNG image copy to a smaller stick go to wallpaper on touch screen and save image .do a master reset .then the FORscan magic !!!!!!!!!!!!!!!
Briankennethcollins
Vehicle: Ford ecoboost 2.3l 2015
Post by Briankennethcollins » Sun Feb 25, 2018 4:05 pm
that makes sense.. any tips to find sync 3.08??
twisterrescue
Post by twisterrescue » Wed Feb 28, 2018 12:09 am
re sync 3.08 you have to look for it .try google good luck !
rferrer100
Post by rferrer100 » Mon Mar 19, 2018 4:10 pm
Just tried it and I'm able to get NAV. I ended up buying an A8 card on ebay.
JDaryn1
Vehicle: Ford Edge, V6 3.5L, 2011
Post by JDaryn1 » Sun Mar 25, 2018 11:36 pm
I just updated my 2011 Ford Edge to have navigation.
Updated SYNC2 to 3.8 (software v3.08).
Used FORScan to change the first two numbers from 00 to 04 in field 7D0-01-02.
the PNG image worked to activate navigation.
Installed Nav update files.
Took about 30 mins total. I have an A3 map card and it works. Now looking for a cheap A8.
The ELM327 interface was a generic one from AliExpress, Model VINT-TT55501.
twisterrescue
Post by twisterrescue » Mon Mar 26, 2018 10:48 pm
Great to here just remember to never update thru fords syncmyride.com you will loose the nav 3.08 is still the highest version you can use current is 3.14 I think
