Ford Focus MK3 "reset all adaptation" function
Postby FocusMK3 » Mon Nov 17, 2014 11:34 pm
Hi, I need some help
I own an european MK3 Ford Focus, year 2011, 1.6 diesel, 115hp
I have used FORScan with ELS27 (purchased from Russian friends), and performed the function "reset all adaptation".
After 40km the Focus is very bad, engine rpm not stable, loud rattle when I accelerate, at cold start is worse, it seems that is not doing the self learning. I have no visible errors on dash (only one for faulty headlight because of HID xenon kit, after tweaking with foCCCus, but lights are ok)
Other info: on my car the main radio , navigation unit and the rear camera are aftermarket, but I don't think this is the issue. The fuel consumption was worse over the last few months.
Soon I will post the current DTC codes. I have cleared the DTC codes before the reset so we will see only newly created ones. Here THE OLD DTC CODES:
Code: Select all
===PCM DTC P02D3:00-6C===
Code: P02D3 - Cylinder 4 Fuel Injector Offset Learning at Max Limit
Status:
 - Test not complete
===END PCM DTC P02D3:00-6C===
===PCM DTC P02CF:00-6C===
Code: P02CF - Cylinder 2 Fuel Injector Offset Learning at Max Limit
Status:
 - Test not complete
===END PCM DTC P02CF:00-6C===
===PCM DTC P02CD:00-6C===
Code: P02CD - Cylinder 1 Fuel Injector Offset Learning at Max Limit
Status:
 - Test not complete
===END PCM DTC P02CD:00-6C===
===PCM DTC P02D1:00-6C===
Code: P02D1 - Cylinder 3 Fuel Injector Offset Learning at Max Limit
Status:
 - Test not complete
===END PCM DTC P02D1:00-6C===
===PCM DTC U0418:00-68===
Code: U0418 - Invalid Data Received From Brake System Control Module
Status:
 - DTC Maturing - Intermittent at Time of Request
 - Test not complete
===END PCM DTC U0418:00-68===
===OBDII DTC None===
Successfull DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII DTC None===
===SASM DTC None===
Module: Steering Angle Sensor Module
===END SASM DTC None===
===ABS DTC U0151:00-60===
Code: U0151 - Lost Communication With Restraints Control Module
Status:
 - Test not complete
Module: Anti-Lock Brake / Traction Control Module
===END ABS DTC U0151:00-60===
===ABS DTC U2300:51-20===
Code: U2300 - Central Configuration
Additional Fault Symptom:
 - Not Programmed
Status:
===END ABS DTC U2300:51-20===
===ABS DTC C1109:64-60===
Code: C1109 - Vehicle Dynamics Control Switch
 - Signal Plausibility Failure
Status:
 - Test not complete
===END ABS DTC C1109:64-60===
===ABS DTC U0126:00-20===
Code: U0126 - Lost Communication With SASM
Status:
===END ABS DTC U0126:00-20===
===ABS DTC U0300:00-20===
Code: U0300 - Internal Control Module Software Incompatibility
Status:
===END ABS DTC U0300:00-20===
===ABS DTC U0140:00-60===
Code: U0140 - Lost Communication With Body Control Module
Status:
 - Test not complete
===END ABS DTC U0140:00-60===
===RCM DTC None===
===END RCM DTC None===
===PSCM DTC None===
Module: Power Steering Control Module
===END PSCM DTC None===
===BCMii DTC B10D7:81-6C===
Code: B10D7 - PATS Key
 - Invalid Serial Data Received
Status:
 - Test not complete
Module: Body Control Module
===END BCMii DTC B10D7:81-6C===
===BCMii DTC U0236:00-6C===
Code: U0236 - Lost Communication With Column Lock Module
Status:
 - Test not complete
===END BCMii DTC U0236:00-6C===
===BCMii DTC B109B:15-6C===
Code: B109B - License Plate Light
 - Circuit Short To Battery Or Open
Status:
 - Test not complete
===END BCMii DTC B109B:15-6C===
===BCMii DTC B1A79:13-68===
Code: B1A79 - Rear Fog Lamp Circuit
 - Circuit Open
Status:
 - Test not complete
===END BCMii DTC B1A79:13-68===
===BCMii DTC U2101:00-6C===
Code: U2101 - Control Module Configuration Incompatible
Status:
 - Test not complete
===END BCMii DTC U2101:00-6C===
===SRM DTC None===
Module: Speech Recognition Module
===END SRM DTC None===
===PDM DTC B12C2:15-2C===
Code: B12C2 - Puddle lamp
Status:
Module: Passengers Door Control Unit
===END PDM DTC B12C2:15-2C===
===PDM DTC U0140:00-28===
Status:
===END PDM DTC U0140:00-28===
===DDM DTC B12C2:15-2C===
Status:
Module: Drivers Door Module
===END DDM DTC B12C2:15-2C===
===DDM DTC U0140:00-28===
Status:
===END DDM DTC U0140:00-28===
===HVAC DTC None===
Module: Heating Ventilation Air Conditioning
===END HVAC DTC None===
===RFA DTC U0140:00-28===
Status:
Module: Remote Function Actuator
===END RFA DTC U0140:00-28===
===IPC DTC U0184:00-2F===
Code: U0184 - Lost Communication With Radio
Status:
Module: Instrument Panel Control Module
===END IPC DTC U0184:00-2F===
Any suggestion will be appreciated
FocusMK3
Vehicle: Ford Focus MK3 1.6 diesel 2011
Re: Ford Focus MK3 "reset all adaptation" function
Postby FocusMK3 » Tue Nov 18, 2014 9:07 pm
After 2 days, the engine was still bad. No improvement.
This evening, at cold start the engine was emitting thick smoke..
I connected again the ELS27 to check dtc with forscan:
Code: Select all
===PCM DTC P02A2:00-2C===
Code: P02A2 - Cylinder 3 Balance - Fuel Trim at Max Limit
Status:
===END PCM DTC P02A2:00-2C===
===PCM DTC U2300:87-28===
 - Missing Message
Status:
===END PCM DTC U2300:87-28===
===PCM DTC B1206:00-28===
Code: B1206 - Crash Occurred
Status:
===END PCM DTC B1206:00-28===
===SASM DTC C1B00:87-28===
Code: C1B00 - Steering angle sensor
 - Missing Message
Status:
===END SASM DTC C1B00:87-28===
===SASM DTC U0140:00-28===
Status:
===END SASM DTC U0140:00-28===
===ABS DTC U0300:00-28===
Status:
===END ABS DTC U0300:00-28===
===ABS DTC U0140:00-68===
Status:
 - Test not complete
===END ABS DTC U0140:00-68===
===ABS DTC C1109:64-68===
Status:
 - Test not complete
===END ABS DTC C1109:64-68===
===ABS DTC U0126:00-28===
Status:
===END ABS DTC U0126:00-28===
===RCM DTC U0300:00-28===
Status:
===END RCM DTC U0300:00-28===
===PSCM DTC U0300:00-08===
Status:
===END PSCM DTC U0300:00-08===
===PSCM DTC U0126:00-08===
Status:
===END PSCM DTC U0126:00-08===
===PSCM DTC U0140:00-08===
Status:
===END PSCM DTC U0140:00-08===
===BCMii DTC B112B:07-28===
Code: B112B - Steering Wheel Module
 - Mechanical Failures
Status:
===END BCMii DTC B112B:07-28===
===BCMii DTC U0151:00-28===
Status:
===END BCMii DTC U0151:00-28===
Status:
 - Test not complete
===BCMii DTC U2101:00-2F===
Status:
===END BCMii DTC U2101:00-2F===
===SRM DTC None===
===PDM DTC B12C2:15-28===
Status:
===END PDM DTC B12C2:15-28===
Status:
===DDM DTC B12C2:15-28===
Status:
===END DDM DTC B12C2:15-28===
Status:
===HVAC DTC U0140:00-28===
Status:
===END HVAC DTC U0140:00-28===
Status:
===IPC DTC U0140:00-28===
Status:
===END IPC DTC U0140:00-28===
===IPC DTC U0121:00-28===
Code: U0121 - Lost Communication With ABS Control Module
Status:
===END IPC DTC U0121:00-28===
===IPC DTC U0151:00-28===
Status:
===END IPC DTC U0151:00-28===
===IPC DTC U0131:00-28===
Code: U0131 - Lost Communication With PSCM
Status:
===END IPC DTC U0131:00-28===
Status:
I read this in the log message
Code: Select all
so I decided to check BCM configuration with foCCCus. After readind BCM and IPC, the engine changed suddenly. Regular at low rpm and normal behaviour..
Strange, I dont know if the vehicle restored a previous copy from a backup, or if the self-learnig ended suddenly.. or the IPC reading restarted some module (all dash counters are resetted after IPC reading I think)
Now I have to deal with the current DTCs.
First of all:
someone know what this mean?
Code: Select all
FocusMK3
Postby FORScan » Wed Nov 19, 2014 4:55 pm
The problem is that it seems the Reset All Adaptations function in case of Focus 3 1.6 TDCi clears important data related to injection. These data must be re-initalized in order to have engine working properly.
Please do the following:
1. Download this new test build:
http://forscan.org/download/FORScanSetu ... 191114.exe
2. Uninstall old version, install this new one.
3. Execute Service function "Reset pilot injection quantity learned values"
4. Clear all DTCs using Reset DTC button.
5. Drive the vehicle for 8 km at least
6. Check again the errors.
Please email us results. It would be interesting to see what are Fuel Injector correction factors before and after the procedure (you can use service function Read Fuel Injector Correction Factors)
Please use email for a quick feedback.
Postby FocusMK3 » Wed Nov 19, 2014 5:25 pm
Thank you for your reply.
I will do the steps as soon as possible.
I suggest also to modify the software to WARN the owners of Focus 3 1.6 TDCi.
Also, I know at least another owner of Focus 3 1.6 TDCi, that have used this function without issues. Maybe the version of the original firmware is different.
I will write results.
Thanks again.
FocusMK3
Postby FORScan » Thu Nov 20, 2014 5:26 am
FocusMK3 wrote:Also, I know at least another owner of Focus 3 1.6 TDCi, that have used this function without issues. Maybe the version of the original firmware is different.
Your complaint is the 3rd one we got on this issue, and all 3 are for Focus Mk3 1.6 TDCi (although this function implemented on many models). We don't know how many Focus Mk3 1.6 TDCi users ran this function successfully, because people usually do not write us if everything is OK.
After analyzing this issue in the past we come to the conclusion this is not a normal PCM behaviour and most likely is a bug in PCM firmware. So, it is quite possible that in later (newer) calibration files this problem was fixed.
We actually think to remove this function for Focus Mk3 1.6 TDCi at all. Experience shows that warnings may not work (some people don't read them). In the meantime, we can try to collect some information about vehicles that experience this probelm - calibration info etc. By the way, can you please email us the calibration data for your vehicle (Configuration Tab, data displayed under Vehicle and PCM sections)?
Postby FocusMK3 » Thu Nov 20, 2014 12:53 pm
I will provide all the info maybe this Saturday.
FocusMK3
Postby mishueen » Fri Nov 21, 2014 1:27 am
hey - i do have the same issue after "adaptation reset"
The new app did not solved the problem, however thank you appreciate your work. Engine is loud and consumption is ...almost double. I drove the car for 12 km....but is still not the car i used to drive.
i am not able to upload new PCM calibration neither.
Cheers
Mishu
mishueen
Vehicle: FOCUS C_MAX 1.6 Duratorq
Postby FocusMK3 » Fri Nov 21, 2014 11:15 am
Mishu, did you use the special build of the application provided some post above?
And did you run "Reset pilot injection quantity learned values" ?
FocusMK3
Postby mishueen » Fri Nov 21, 2014 1:55 pm
Yes i did. I spent hours trying to learn the vehicle that i am the owner.... :)
Immediately after servicing there was a lot of rattle and diesel specific crank. After 30km the noise decreased.. A new start and the noise was back.
During my tests noticed HUGE fuel consumption. Unfortunately is still the same the consumption. Apparently the noise eased. Can you please let me know about the "learning" process how long it usually takes? Still hoping the car coming back to silent run with a decent fuel consumption. ( for your info 6th gear highway 100km/h autopilot plain road i gget a fuel average of 7.6l /100 km.
This is not good -in these conditions i used to get under or somewhere arround 5l/100km.
If you have any guidance i would appreciate.
cheers
mishueen
Postby mishueen » Sat Nov 22, 2014 8:55 pm
Do i need to load calibration for PCM? If so i need to go to dealer to use IDS since focccus return an security error at 1% when attempting to load PCM .vbf.
mishueen
Next
Return to Diagnostics and Maintenance using FORScan
Who is online
Users browsing this forum: No registered users and 3 guests
