PATS Key Programming
Re: PATS Key Programming
Postby alan71 » Tue Aug 11, 2015 1:52 am
Same here on a 2008 sport trac! Can erase all keys and get 1st key to program but 2nd key will not!! Keys are OEM.
alan71
Vehicle: 2008 Ford Sport trac,v6
Postby FORScan » Tue Aug 11, 2015 2:47 pm
alan71 wrote:Same here on a 2008 sport trac! Can erase all keys and get 1st key to program but 2nd key will not!! Keys are OEM.
Are you sure the second key is valid? Can you check all keys as described here:
viewtopic.php?f=6&t=1581
If both keys return B1601, please send internal FORScan logs to PM or email for further analysis of the problem. Instruction is on the Contact Us page.
Postby tutti2000 » Wed Aug 19, 2015 11:17 am
I have a problem to program a new key to my Ford Focus build 2002 1.8 TdCi, which was built in the netherlands. After I#m getting the Outcode I went to the hompega autokeyprog and I was given an incode. After Typing that incode and pressing OK ForScan exits with message taht the key is programmed succesfully. But the car doesn't start with that key.
Is it right that I have to insert first a programmed key and when the message box appears I have to turn off ignition and have to put in the new one?
Greets from Germany
Stefan
tutti2000
Vehicle: Focus MK1, 1,8 Gasoline
Postby FORScan » Thu Aug 20, 2015 1:21 pm
tutti2000 wrote:I have a problem to program a new key to my Ford Focus build 2002 1.8 TdCi, which was built in the netherlands. After I#m getting the Outcode I went to the hompega autokeyprog and I was given an incode. After Typing that incode and pressing OK ForScan exits with message taht the key is programmed succesfully. But the car doesn't start with that key.
Such behaviour is possible on this model if the key is not right (transponder is not compatible). Can you please check the key as described here: viewtopic.php?f=6&t=1581 ?
Postby tutti2000 » Fri Sep 04, 2015 4:57 am
Hello FORScan,
you were right. The Transpoder of the new key doesn't be recognized by the PCM. Someone sold me the wrong key for this car. I Have ordered an new transponder (4D60) which should fit for this car. I will try it as soon as the transponder arrives. And when everything is fine with this transponder I have to operate it into the flip key.
Greets and thanks
Stefan
tutti2000
Postby tutti2000 » Thu Sep 10, 2015 8:09 am
Hello, FORScan,
I now programmed the new key. What a bast*** who sold me the key and said it would be plug an play. With the new transponder everything works fine. I programmed the key with FORScan in five minutes. Thanks for the hel and the good Tutorial!
Greets, Stefan
tutti2000
Postby FORScan » Thu Sep 10, 2015 10:49 am
Thanks for the update, great news :)
Postby vio77 » Tue Sep 15, 2015 7:06 pm
Hello Forscan,
i'm tryng to program keys to a Ford fiesta 2006 my and get a message that says Service procedure stopped.Get in touch with developers.I'm stuck ,any ideas?
Forgot to mention that i received extended licence and read posts on forum about programing(thank you for the licence and very good tutorials).
vio77
Vehicle: ford mondeo mk2 1,8td
Postby FORScan » Wed Sep 16, 2015 7:44 am
Please try version 2.2.6 (released today) and if it still doesn't work, please send us internal FORScan log as described here: http://forscan.org/contactus.html
Postby vio77 » Wed Sep 16, 2015 1:07 pm
Updated to 2.2.6 versión but still no luck,still stops. :cry: :cry:
vio77
PreviousNext
Return to General and Support forum
Who is online
Users browsing this forum: lucaspeed and 11 guests
