In Wine emulation under Linux, FORScan was unable to detect the COM port until I added the following registry entries (by editing the file ~/.wine/system.reg):
WINE REGISTRY Version 2
;; All keys relative to \\Machine
#arch=win32
[Hardware\\Devicemap\\Serialcomm] 1015709345
"Serial0"="COM1"
Clarification from Dick Saarloos (Ford Fiesta Mk6.5, Dutch Fiestaclub http://www.fiestaclub.nl):
As a Linux Kubuntu user I had some troubles to get it working under WINE1.6 but found the solution. In the HOWTO you just mention its enough to edit the ~/.wine/system.reg but could not activate the COM - USB port within FORscan.
I got it running after changing/configuring some settings within Kubuntu 13.10, 14.04
a. after plugging in verification with LSMOD showed the adapter visible as lp2303 and usbserial (easy so far)
b. with ls -la /dev/tty* the adapter will be visible as /dev/ttyUSB0 and can be simply tested with a console program like screen /dev/ttyUSB0 (interrupt screen with unplugging the adapter)
c. I made my username member of the dialgroup. First check with id-Gn. With sudo adduser dicks dialout I became member of the dialgroup. Checked it with id-Gn
d. for WINE you have to create a symbolic link for the com1 device with ln -s /dev/ttyUSB0 ~/.wine/dosdevices/com1
Without this symbolic link no com device will be seen in wine/dosdevices
To get it working for Bluetooth ELM is very simular like the way it has to be done with a USB ELM. So user/group policy is the same.
a. With LSMOD the modules rfcomm and bluetooth must be visible
b. If blue-man is installed, start blueman, start search device, add the OBDII adapter by means of the "green plus", click on the PIN-key and type in 1234, trust the device with the yellow star, click on configure and select for Serial Port. Wait for message that device is available via the rfcomm0 port
c. Check with ls -l /dev/rfcomm0 is available
d. Change for WINE by editing the file ~/.wine/system.reg the entry for Bluetooth the Serialcomm setting to COM5:
#arch=win32
"Serial0"="COM5"
e. Create a symbolic link for the com5 device with ln -s /dev/rfcomm1 ~/.wine/dosdevices/com5
FORScan runs fine under WINE but after disconnecting the Bluetooth adapter it does not reconnect automaticly as it does under XP. The only possibility to reconnect as I found out till now is to delete the Bluetooth device and to configure it again.
