Performance fix of china ELM327 WiFi adapter
Re: Performance fix of china ELM327 WiFi adapter
Postby FORScan » Fri Aug 08, 2014 9:22 am
Wild E Coyote wrote:I notice that OBD scanners get rather hot during operation. Is that normal? Perhaps they heat up to much, up to the point of affecting their performance?
Yes, it seems all china ELM327 WiFi become hot, but we didn't notice any influence to performance.
By the way, we are testing now OBDLink MX WiFi, it is much colder, although 3-4 times faster than any china WiFi adapter.
Postby Wild E Coyote » Fri Aug 08, 2014 9:52 am
I am using a HP laptop with atom processor (1.6 MHz) and windows XP with all the patches (original, payed for windows XP instalation). It should be fast and strong enough for handling Forscan, shoudln't it?
When I get home, will do the logs as you requested
Wild E Coyote
Vehicle: Ford puma, petrol, 1.7/125 bhp, 2001
Postby FORScan » Fri Aug 08, 2014 10:35 am
Wild E Coyote wrote:I am using a HP laptop with atom processor (1.6 MHz) and windows XP with all the patches (original, payed for windows XP instalation). It should be fast and strong enough for handling Forscan, shoudln't it?
Yes, it should work fine in this configuration.
Postby infidel » Sun Aug 24, 2014 3:45 pm
Anyone know the username/pass for a wifi obd2 adapter with "CLKDevices" as wifi name? Tried standard admin/admin etc but none work
infidel
Vehicle: MX-5 1,8 - 126hp - 2008
Postby xiabingling » Fri Sep 12, 2014 6:03 pm
So helpful! :D :D
xiabingling
Vehicle: BMW,SUVEOER,2012
Postby smartapps4me » Wed Sep 17, 2014 10:14 pm
Do you want try Smart Control?
Now you can enter community and proceed with the download of the app in beta testing.
https://plus.google.com/u/0/communities/115968206197314187335
smartapps4me
Vehicle: Peugeot 508
Postby Tony Back » Fri Sep 19, 2014 7:27 am
There are so many ELM 327,they all support WIFI functions. What's the difference among Vgate elm 327 and other elm 327s? :?:
Tony Back
Vehicle: Ford Focus
Postby FORScan » Mon Sep 22, 2014 4:53 am
Tony Back wrote:There are so many ELM 327,they all support WIFI functions. What's the difference among Vgate elm 327 and other elm 327s? :?:
Unfortunately, a cheap china adapter is always a lottery. We purchased Vgate bluetooth a year ago and it worked just great. Vgate WiFi purchased a half of year ago works ok as well. But in the past we got complaints from user who purchased adapters with label Vgate and had problems with them.
This is why in the past we recommend to purchase while label solutions like OBDLink MX. They are more expensive, but have good stability and performance. They are also better suit to Ford because of built-in MS-CAN support.
Postby Tony Back » Wed Oct 29, 2014 6:05 am
I just broke my piggy bank for a new sweet mini elm 327 with switch to play with. cheap $12 and much small previous elm327. Plug it into the vehicle's 16 pin socket, turn on the power, wait for the LEDs illuminates, attach the WIFI community of iOS system, and go to the App’s main program, start your first scan and enjoy seeing your engine’s available parameters like Vehicle speed, PRM, fuel pressure, mass air flow, EVAP System Vapor Pressure, Fuel Consumption,etc. The biggest advantages of this new super mini elm327 is that it comes with a built-in power switch to prevent the need for having to constantly disconnect your unit from the OBDII port.
I have made some comparison and found a most cheap one. Other may cause 10$ more than the price
<URL removed by moderator. Advertisement is not allowed on this forum>
Tony Back
Vehicle: Ford Focus
Postby King Graham » Tue Feb 17, 2015 5:40 am
Have you guys had any luck with Vgate's iCar2 adapter? I mean this one:
I've been using that to read my dad's Ford fault codes using Forscan. However, when I read my own BMW's fault codes using BMWhat app I started to suspect whether or not it finding all the ECUs. I contacted app's developer and he confirmed from the logs that adapter is not catching all responses from the car.
Unfortunately adapter settings are different than iCar1's settings - there is no setting for TCP-serial timeout. All the settings I can find are as shown below.
Or should I just go with OBDlink MX? Another option that I'm thinking which is a bit cheaper is BMWhat's own adapter (http://www.ivini-tech.de/en/adapter/ios-bmw/original-ivini-tech-iphone-ipad-wifi-adapter-for-bmw/a-1003/). Do you guys have any experience with that using Forscan?
King Graham
Vehicle: BMW E91LCI 320da 2010
PreviousNext
Return to Adapters & Connection
Who is online
Users browsing this forum: No registered users and 7 guests
