2008-10 F250 SuperDuty Spreadsheet...
Postby rixter99 » Sat Feb 10, 2018 3:28 am
Limited, but ready...
Cheers, Rick
Link to 2008-2010 F250 Spreadsheet
https://docs.google.com/spreadsheets/d/ ... sp=sharing
rixter99
Vehicle: 2008 F250 SD XLT 6.4L Diesel 2WD
Re: 2008-10 F250 SuperDuty Spreadsheet...
Postby rixter99 » Tue Feb 13, 2018 10:27 pm
Cheers, Rick
rixter99
Postby mrglee » Thu Mar 01, 2018 3:23 am
Thank you for posting the 08-10 SD spreadsheet. I was able to enable RKE on my 08 F-250 and program a remote transmitter and also a key with built-in remote transmitter. Mine doesn't use PATS either so I just need to get the key cut and I'll be all set.
mrglee
Vehicle: 2008 F-250 6.4 Manual
Postby rixter99 » Thu Mar 01, 2018 3:54 am
GREAT...Glad it helped...
Cheers, Rick
rixter99
Postby mrglee » Fri Mar 09, 2018 3:34 am
Hello, for RKE at 726-04-01 I had programmed 02** and then programmed my fob and my key with built-in fob buttons. Its been great to have this feature enabled but the other day I happened to notice that the panic button on eiher fob doesn't do anything. I was wondering if your panic button works with RKE and, if so, what value you programmed at 726-04-01. Thanks again
mrglee
Postby rixter99 » Fri Mar 09, 2018 5:19 am
No sir, my panic button didn't work either after enabling RKE...I'm thinking the PANIC may be part of the PATs (perimeter anti-theft?) or other Security Group feature which was not an option on my truck and since my truck doesn't use a 'chip-key', I'm hesitant to enable either of those via FORScan...Also, I don't know if the BCM/SJB module (behind passenger kick panel) enables/disables that or a separate Security 'box' is needed...
Cheers, Rick
rixter99
Return to Configuration and Programming
Who is online
Users browsing this forum: No registered users and 5 guests
